Help for InfluxQL to Flux
Hello community.
Is there anyone here who can translate 2 lines from influxQL to Flux for me? Unfortunately I can’t find any comparable examples. It’s about a query of an influxDB 2 database.
SELECT Total_Ticks FROM Weather_station ORDER BY DESC LIMIT 1
…and the second query:
SELECT difference(max(“Total_Ticks”)) FROM “Weather_station” WHERE time>now()-2d and time <= now() group by time(1d) tz(‘Europe/Berlin’)
I already know how to set the filters so that I get the right data:
from(bucket: “bucket”)
|> filter(fn: (r) => r[“_measurement”] == “Weather_station”)
|> filter(fn: (r) => r[“_field”] == “Total_Ticks”)
But then I just don’t know what to do ;-(
For someone who is fit in Flux, this is certainly easy. But for me it is an insurmountable obstacle.
Can someone help please?
Beste regards
Welcome @weissglut
Maybe this?
|> range(start: -2h) // Query a time range relative to now
|> filter(fn: (r) => r["_measurement"] == "Weather_station")
|> filter(fn: (r) => r["_field"] == "Total_Ticks")
|> max() // returns the row with the maximum value in a specified column from each input table
|> difference() // returns the difference between subsequent values
|> limit(n: 1) //  returns the first n rows
|> yield(name: "your-query")
Since you are getting 1 row with the above query, I am not sure you need to worry about putting in an aggregateWindow(every: 1d, fn: mean) function.
Hello and thank you for the quick reply. I am not sure if I understood everything correctly. The first query in influxQL is:
SELECT Total_Ticks FROM Weather_station ORDER BY DESC LIMIT 1.
Translated into Flux:
from(bucket: "bucket")
    |> filter(fn: (r) => r["_measurement"] == "weather_station_Igersheim")
Did I understand that correctly?
And for the second query:
SELECT difference(max("Total_Ticks")) FROM "Weather_station" WHERE time>now()-2d and time <= now() group by time(1d) tz('Europe/Berlin')
Is the correct “translation”
Is that correct?
What does “|> yield(name: “your-query”)” mean?
And how can I find out if “aggregateWindow(every: 1d, fn: mean)” is necessary?
Thanks a lot for any feedback!
Sorry, I was going too fast yesterday and did not realize you had 2 queries. The yield statement is needed to put the results into a table that can be viewed in Influx Data Explorer.
I’ll try to post back in the next 24 hours or when time allows.
should be something like this:
from(bucket: "your-bucket-name")
    |> sort(columns: ["_time"], desc: true)
    |> limit(n: 1)
    |> yield(name: "query1")
import "timezone"
    |> range(start: -2d, stop: now())
    |> aggregateWindow(every: 1d, fn: max, createEmpty: false)
    |> difference(nonNegative: false, columns: ["_value"])
    |> map(fn: (r) => ({ r with _time: timezone.shift(t: r._time, location: "Europe/Berlin")}))
I am a bit sketchy about the whole timezone thing. I always store data in InfluxDB in UTC and then use the local time zone when I am querying it (in InfluxDB or Grafana).
Try running the above in Influx Data Explorer with Raw Data toggle enabled and see if they produce the correct results.
Hello grant1.
Thank you very much for your support! With your first solution for
I get the following error message in Influx Data Explorer as well as in the NodeRed application:
error in building plan while starting program: cannot submit unbounded read to "bucket"; try bounding 'from' with a call to 'range'
A time range still needs to be defined here, right?
There also seems to be a problem with the second query:
error @9:40-9:48: record is missing label shift
Do you have any idea what is going wrong here?
Many greetings
Weissglut
Hi @weissglut
In the first query, just insert a range function like
and you should be good there.
In the second query, like I said, my skills are a bit sketchy on the whole timezone thing. Does this work (basically remove the timezone stuff)?
EDIT: If the above works, try putting this in at the very beginning before the from(bucket) statement, and see if it still works with the correct time:
import "timezone"
// Set location to be Europe/Berlin
option location = timezone.location(name: "Europe/Berlin")
Hello grant1
Now it works without error message! Perfect.
Thanks a lot for your support. Without this platform and your help, I probably wouldn’t have been able to do this.
Many greetings
