Flux to InfluxQL?
i need some help converting a Flux Query into InfluxQL:
import "timezone"
// Set location to be Europe/Berlin
option location = timezone.location(name: "Europe/Berlin")
from(bucket: "solarpower")
  |> range(start: -12mo, stop: now())
  |> filter(fn: (r) => r["_measurement"] == "solar")
  |> filter(fn: (r) => r["_field"] == "todaykwh")
  |> aggregateWindow(every: 24h, fn: last, offset: -1s, createEmpty: false)
  |> truncateTimeColumn(unit: 1m)
  |> aggregateWindow(every: 1mo, fn: sum, createEmpty: false, timeSrc:"_start")
For Grafana Ouput of 12 Bars.
@Starfoxfs I believe this query will work for you, but it may not:
SELECT
  SUM(last_todaykwh) AS "monthly_sum"
FROM (
  SELECT
    last(todaykwh) AS "last_todaykwh"
  FROM
    solarpower..solar
  GROUP BY
    time(24h, -1s)
GROUP BY
  time(every: 30d)
WHERE
  time >= now() - 365d
  AND time < now()
TZ('Europe/Berlin')
InfluxQL isn’t quite as flexible as Flux and doesn’t support all of the same duration units (mo for example).
This isnt working correctly, I used it in Grafana and get the Error:
Time column doesnt exists from the last GROUP BY clause.
If i delete the last GROUP BY clause the Query works but makes a sum of alle Last todaykwh in 24h hours thats correct but i need a the Last Todaykwh of all 24Hours for 12 month calculated per Month.
The First SELECT does not connect to a Database its only a calculation of the Second SELECT so the first SELECT cant have a Time column and so the last GROUP BY cant work.
But i dont know how to do this correctly with UNION ?!?
InfluxQL doesn’t support UNION. I assume you’re using InfluxDB v2 to run this query and are converting it to InfluxQL. Is there a specific reason you want to use InfluxQL instead of Flux?
InfluxDB3 is the reason :grinning_face:
There are some Flux queries that can’t be replicated in InfluxQL. I think this query falls in that category. However, you would be able to run a similar query using SQL in InfluxDB 3. The InfluxDB 3 SQL implementation provides more flexibility with subqueries than InfluxQL and it supports UNION. You might need to wait until you move the InfluxDB 3 before you can restructure this query using SQL.
Hi, I didn’t try your flux query specifically, but I found AI chatbots to be quite good at the conversion. This is what it spitted out:
SELECT SUM(“daily_kwh”)
FROM (
SELECT LAST(“todaykwh”) AS “daily_kwh”
FROM “solar”
WHERE time >= now() - 12mo
GROUP BY time(1d)
GROUP BY time(30d)
