Hi!
We have alot of telegraf metrics and other metrics in influx now.
And using chronograf to visualize it is sometimes not so easy.
Scenario:
A disk is running out of free space.
I go to the data explorer to find out which server and which disk is running low.
Now these problems are hard to screenshot so I did a screen recording.
Since I can not upload a video clip of my screen recording, I shared it here:
https://s3-eu-west-1.amazonaws.com/hasselrot-temp-bucket/Disk_used.m4v
As you can see its not very easy to find the data you are looking for, when you have a lot of metrics.
It does not sort in the order of high to low
Sometimes the list gets so long it disappears outside my browser
Sometimes the list only shows some data
Its very sensitive where the mouse pointer is, making the list flash back and front all the time
Is there a better way to do this?
