Log Viewer not working when deployed with Helm
Hi
I’ve deployed using the Helm charts and everything is working except the Log Viewer in Chronograf.
The problem is that it only shows “_internal.monitor” db as a source. “telegraf.autogen” has a syslog measurement (I can query this data and put it in a dashboard table visualization) but it is not available from the DB dropdown in the log viewer.
Any ideas?
Thanks,
Wayne
This is resolved - after a few hours the log viewer seems to have auto discovered the syslog metric in the telegraf database.
Thanks,
Wayne
Just one more note on this for anyone who has the same issue. The source list seems to be cached, opening the UI in an incognito window shows the full list while a window with history only shows “_internal” source.
