I’m trying to make a non derivative query with an interval that come from the database:
select * from "test_interval" limit 2
time tag1 host interval meter_type ns task_name test value
2020-04-23T00:00:00Z test server01 10s ram foo task1 10s 41
2020-04-23T00:00:00Z test server01 10s time foo task1 10s 39
interval is a tag, test is a value.
When querying I got this:
SELECT non_negative_derivative(mean("value")) FROM "test_interval" WHERE time >= now() - 12h GROUP BY time("interval")
ERR: time dimension must have duration argument
SELECT non_negative_derivative(mean("value")) FROM "test_interval" WHERE time >= now() - 12h GROUP BY time("test")
Got same behavior with influx 1.8 and 1.6.
Is there a way to group by time with an interval from a db field ?
Best regards,
