I am working with influxdb 1.7
I have a measurement named “test” like below
SELECT * FROM test
time code host f_range value
1610532240000000000 a localhost 0.101~0.200 7
1610532240000000000 a localhost 0.401~0.500 1
1610532240000000000 b localhost 0.101~0.200 3
1610532300000000000 b localhost 0.101~0.200 3
1610532300000000000 b localhost 0.201~0.300 1
1610533020000000000 a localhost 0.101~0.200 4
1610533020000000000 a localhost 0.201~0.300 1
1610533020000000000 a localhost 0.401~0.500 1
1610533020000000000 b localhost 0.101~0.200 6
1610533620000000000 a localhost 0.101~0.200 11
1610533620000000000 b localhost 0.101~0.200 8
And I can also make it group by tag values like …
> SELECT sum("value") FROM "test" WHERE ("code" =~ /^a$/ AND "host" =~ /^localhost$/) AND time >= now() - 30m GROUP BY "f_range" fill(0)`
tags: f_range=0.101~0.200
time sum
1610500909884441460 22
tags: f_range=0.201~0.300
time sum
1610500909884441460 1
tags: f_range=0.401~0.500
time sum
But when I add time(1m) condition to the query it just return nothing.
I wonder what should I have to check in this case.
SELECT sum(“value”) FROM “test” WHERE (“code” =~ /^a$/ AND “host” =~ /^localhost$/) AND time >= now() - 30m GROUP BY time(1m), “f_range” fill(0)
this returns nothing but a prompt >
