I’m not able to get the graph to display correctly when I apply a quantile function in my query.
My query:
aeInBps = from(bucket: "bb_interfaces_test")
|> range(start: -10m)
|> filter(fn: (r) => r._measurement == "interfaces" and (r._field == "in-octets"))
|> filter(fn: (r) => r.device =~ /chgo/)
|> drop(columns:["path", "system_id"])
|> group(columns: ["interface-name", "device"])
|> aggregateWindow(every: 1m, fn: last)
|> derivative(unit: 1m, nonNegative: true, columns: ["_value"])
|> map(fn: (r) => ({ r with _value: float(v:r._value) / 60.0 * 8.0 }))
// |> yield()
aeInBps
|> quantile(q: .99, method: "exact_selector")
|> yield()
If I remove the last 3 lines from the query (basically taking out the quantile part) then the graph prints out correctly.
Good output:
Bad output:
Thank you.
