Using the quantile function, I was able to get 95 % percentile value in a stream.
Now, i want to filter records which lie below the 95% percentile.
hence, I loop over my recods and filter records which lie below the percentile.
However, at this topic I get error –
Please find code below –
percentile = totalTimeByDoc
|> filter(fn: (r) => r["documentType"] == "PurchaseOrder")
|> group(columns:["documentType"])
// |> yield()
|> quantile(column: "processTime", q: 0.95, method: "estimate_tdigest", compression: 9999.0)
|> limit(n: 1)
|> rename(columns: {processTime: "pt"})
Give me data – >
0 PurchaseOrder 999
Now, I try to loop over my records and filter -
percentile_filered = totalTimeByDoc
|> filter(fn: (r) => r.processTime < percentile[0]["pt"])
|> yield()
Where, totalTimeByDoc is like below –
|0|PurchaseOrder|testpass22PID230207222747-1|1200|
|1|PurchaseOrder|testpass22PID230207222747-2|807|
|2|PurchaseOrder|testpass22PID230207222934-1|671|
|3|PurchaseOrder|testpass22PID230207222934-2|670|
I get following error from above query –
error @116:41-116:51: expected [{A with pt: B}] (array) but found stream[{A with pt: B}]
