Hi there,
I noticed that when try to get results in the grafana dashboard with past time range it won’t appear. I expect just updating the time range in the Grafana dashoard would do the job.
However at the time of the run, I can see the data in the same grafana dashboard item.
The data pushing to influxdb from Jmeter.
Just curious whether there is a diffence in the influxQL query when extract past data to Grafana.
Below is one of the dashboard item query I use
SELECT sum("count") FROM "$measurement_name" WHERE ("application" =~ /^$application$/ AND "transaction" = 'all') AND $timeFilter GROUP BY time($__interval) fill(null)
