I’m trying to make a query with a fixed time range, based on the time selection.
As an example I want the last 3 days of data, starting from the maximum selected time.
Grafana provides something to address this out of the box, the relative-time, but sadly it works only as long as the time selection is relative (ie: last 5m|3h|2d), when the selection becomes absolute (from/to have a specific date-time) it does not work and fetch the data based on the actual selection.
Therefore I decided to make it manually since there are two variables that contain the time selection $__from and $__to, what I did is use $__to to define lower and upper date-time limit, the problem is that the query sent to influx is not valid,
I’ve tried the same in Chronograf and it works properly.
Those are my queries
#Chronograf Query - Working
SELECT
mean("value") AS "Avg Size"
FROM "monitor"."short"."sqlserver_performance"
WHERE
"sql_instance" =~ /^GSVSQL25$/
AND "counter" = 'Data File(s) Size (KB)'
AND "instance" !~ /^(master|model|mssqlsystemresource|Total)/
AND "time" > (:upperDashboardTime: - 3d)
AND "time" <= :upperDashboardTime:
GROUP BY
time(1d)
,"instance"
#Grafana Query - Not Working
SELECT
FROM "sqlserver_performance"
WHERE
"sql_instance" =~ /^$Var_Sql_Instance$/
AND "time" > ($__to - 3d)
AND "time" <= $__to
GROUP BY
time(1d)
,"instance"
# What Grafana sends to InfluxDB
SELECT
WHERE
AND "time" > (1584140399000 - 3d)
AND "time" <= 1584140399000
GROUP BY
time(1d)
,"instance"
After some trial and error, I’ve discovered that this is the section that makes the query invalid
AND “time” > (1584140399000 - 3d)
AND “time” <= 1584140399000
Does anybody have suggestions about how to solve this kind of problem?
