We are using version 1.7 and migrating to 2.0. (Ideally looking for a solution that also works on 1.7, but I am sure that Flux has many options).
I want to define just using influxdb and Grafana a time range for a query where the time range is based on the time field of an influxdb (sub) query.
So in the simplest implementation, I want to find say the time of the last(value) FROM
Then use that time to calculate n seconds before and after it for from and to respectively.
In the final implementation, I want to define a Grafana variable with all the times retuned by the query and then generate repeating panels for each time (range).
@Eric_Smith1 This is totally doable in Flux, and I think 1.7 has a new enough version of Flux to make it work.
The following query uses some timestamp manipulation and string interpolation to generate from and to timestamps for each row base on n seconds added/subtracted to the points _time value. I don’t the exact format you’d need to populate a grafana variable, but the keep() function at the end keeps only the from and to columns in the output.
