I’ve set up a process in my application that allows me to send a request to a Golang InfluxDB client, such that a user can update a bucket’s retention time. The form to update the time takes in a number of days, converts that into seconds and then sends that number to the Golang client to update the requested bucket.
However, when I enter a number of days equal to, say, 99999, I will be returned an error from the client: unprocessable entity: expiration seconds must be greater than or equal to one second
This does not seem to be a problem with magnitude because I can go to a higher amount of days - like 100000 - and the process will work as intended. However it seems to be that a large number of 9s in days causes this problem.
are you creating buckets with retentions of seconds or days?
Finally, can you please share some of your go client code?
@jos it looks to me like you’re hitting an int overflow when some piece of the system converts seconds → time.Duration (nanoseconds), I’ll try to track it down. The end result will likely still be an error, but with a more-understandable message.
@dan-moran I should clarify that my retention value has been in days, not seconds (that is, the bug happens when I chose 99999 days, not 99999 seconds)
