Execute Influx on CLI
Hi community,
I’m a totally newbie on influxDB, I have an already DB installed on RHEL7 and I’m try to do some tests using the CLI.
The following command works perfect and show me the databases:
# influx -host x.x.x.x -execute 'SHOW DATABASES'
The question is simple, how can I combine 2 commands like:
# influx -host x.x.x.x -execute 'use stat, show series'
So just use a specif database and then show series on this DB.
Thank you
EDIT: To be more clear, what I have to do is something like:
# influx -host x.x.x.x -execute 'use stats; DELETE from status'
ERR: Database stats; DELETE from status doesn't exist. Run SHOW DATABASES for a list of existing databases.
DB does not exist!
Hello @LordSpectre,
You would do something like:
USE stat
SHOW SERIES on stat
But it looks like that db doesn’t exist for you yet, so youll need to create one first.
Thank you, the DB exists, it’s my fault, I reported the output command from other server :slight_smile:
I used something like:
influx -host x.x.x.x -execute 'DELETE from status' -database="stats"
But this is also working fine:
influx -host x.x.x.x -execute 'show series on stats'
But this is not working:
influx -host x.x.x.x -execute 'delete from status on stats'
Then I still don’t understand if it’s possible to concatenate two other commands in one CLI row like:
show series
DELETE from status
@LordSpectre thanks for sharing your solution and thought process
