Error with curl
Hey I am pretty new to InfluxDb and I have some trouble when creating a databas via curl in the Influx Shell.
Can somebody help?
Hi @Sol_Invictus, Welcome !
Curl is not used within the influx shell ,
Here is a curl example to create a database Create database
Hope this helps …
Ps you can also create a database with the influx commandline
Hey Marc thanks for your answer!
I need the curl command because I want ro write Data Points from a file into Influx.
Is the Http API something different than the Influx Shell? How can I acess it?
Thank you
Hi ,
to create a database with curl , you can start curl from the command prompt :
curl -i -XPOST http://localhost:8086/query --data-urlencode “q=CREATE DATABASE mydbfromcurl”
and to go to the influx shell (cli ) you can type influx to enter the shell
and type your commands in the shell ,
or for example : influx -execute “show databases”
you can write datapoints from a file to the database as follows :
curl -i -XPOST ‘http://localhost:8086/write?db=Mydb’ --data-binary @cpu_data.txt
but it is better explained in the link I posted :slight_smile:
Hi Mark,
Thanks for your Help! I figured it out.
Now I am trying to curl this sample dataset into Influx, but it doesnt recognise the dataset.
Here is the dataset: GitHub - influxdata/influxdb-sample-data: Sample time series data used to test InfluxDB
Thanks again for your help.
Hi ,
that dataset is 4 years old and contains json formatted data :slight_smile: ,
do you want to upload json formatted data ?
Writing points from a file
Write points from a file by passing @filename to curl . The data in the file should follow InfluxDB’s line protocol syntax.
Example of a properly-formatted file ( cpu_data.txt ):
cpu_load_short,host=server02 value=0.67
cpu_load_short,host=server02,region=us-west value=0.55 1422568543702900257
cpu_load_short,direction=in,host=server01,region=us-west value=2.0 1422568543702900257
Write the data in cpu_data.txt to the mydb database with:
curl -i -XPOST 'http://localhost:8086/write?db=mydb' --data-binary @cpu_data.txt
Hey
Actually its not important.
I just want to write a big dataset into influx.
Do you maybe have a better dataset I can write into Influx?
sure here it is :slight_smile: … sample data
How can I Download the Data there ?
I just see graphs when I click on a station in a state.
Hi , yes ,
The data is here :
https://s3.amazonaws.com/noaa.water-database/NOAA_data.txt
Hey thanks got it.
Now I am follwing the instructions on this site:
And I get a error message when I use the command:
influx -import -path=NOAA_data.txt -precision=s -database=mydb
It says that it expects something like “CREATE” or “SHOW” after the Influx command.
Do you know what the Problem could be?
