The new UI of InfluxDB free account allows SQL queries only.
I manually uploaded the NOAA dataset but when I try to run a simple SELECT * FROM…
I get this error:
executing query: failed to create Flight record reader: arrow/flight: could not create flight reader: arrow/ipc: could not read schema from stream: arrow/ipc: could not read message schema: rpc error: code = InvalidArgument desc = Error while planning query: Schema error: No field named ‘time’.
