We are using telegraf statsd plugin. We have a legacy code which is emitted tons of measurements which are not optimized for influxdb and we dont use it. As we dont have dev resources we dont want it to bomboard influxdb. currently it is generated 7,00,000 measurements. I am running a python program which iterates over all the 7, 00 ,000 measurements and run DROP MEASUREMENT against individual measurement. It is running very slow. Is there any way to blacklist the measurements from server side ? we did consider namedrop in telegraf (under inputs.statsd) it seems to be not working. Please advise. We did try namedrop in [[inputs.statsd] some how its not working
Any suggestions ? We badly need to address our problem
@davidgs any thoughts?
@hellobhaskar Can you post your statsd configuration and maybe we can figure out why the namepass setting isn’t working for you. We might also be able to show you how to setup the config templates to send in a more InfluxDB friendly way. Include an example of the stats that are being sent too.
@daniel I have the following setup
OS: Ubuntu 18.04.2 LTS
Telegraf: 1.10.2-1
InfluxDB: 1.1.1
Telegraf config
[[inputs.statsd]]
[[outputs.influxdb]]
namedrop = ["uwsgi.worker.*.core.*.write_errors", "uwsgi.worker.*.respawns"]
Telegraf logs after restarting
(venv) vagrant@ubuntu:~$ sudo service telegraf status
● telegraf.service - The plugin-driven server agent for reporting metrics into InfluxDB
Loaded: loaded (/lib/systemd/system/telegraf.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2019-06-01 10:47:02 UTC; 4s ago
Docs: https://github.com/influxdata/telegraf
Main PID: 959 (telegraf)
Tasks: 11 (limit: 4703)
CGroup: /system.slice/telegraf.service
└─959 /usr/bin/telegraf -config /etc/telegraf/telegraf.conf -config-directory /etc/telegraf/telegraf.d
Jun 01 10:47:02 ubuntu telegraf[959]: 2019-06-01T10:47:02Z I! Loaded processors:
Jun 01 10:47:02 ubuntu telegraf[959]: 2019-06-01T10:47:02Z I! Loaded outputs: influxdb
Jun 01 10:47:02 ubuntu telegraf[959]: 2019-06-01T10:47:02Z I! Tags enabled: host=ubuntu
Jun 01 10:47:02 ubuntu telegraf[959]: 2019-06-01T10:47:02Z I! [agent] Config: Interval:10s, Quiet:false, Hostname:"ubuntu", Flush Interval:10s
Jun 01 10:47:02 ubuntu telegraf[959]: 2019-06-01T10:47:02Z D! [agent] Connecting outputs
Jun 01 10:47:02 ubuntu telegraf[959]: 2019-06-01T10:47:02Z D! [agent] Attempting connection to output: influxdb
Jun 01 10:47:02 ubuntu telegraf[959]: 2019-06-01T10:47:02Z D! [agent] Successfully connected to output: influxdb
Jun 01 10:47:02 ubuntu telegraf[959]: 2019-06-01T10:47:02Z D! [agent] Starting service inputs
Jun 01 10:47:02 ubuntu telegraf[959]: 2019-06-01T10:47:02Z I! Statsd UDP listener listening on: [::]:8125
Jun 01 10:47:02 ubuntu telegraf[959]: 2019-06-01T10:47:02Z I! Started the statsd service on :8125
Measurements in InfluxDB
> show measurements
name
alerta_alerts
cpu
disk
diskio
kernel
mem
processes
swap
system
Now, I tried emitting some statsd metrics
echo "uwsgi.worker.0.core.0.write_errors:1|c" | nc -w 1 -u localhost 8125
echo "uwsgi.worker.1.core.0.write_errors:1|c" | nc -w 1 -u localhost 8125
echo "uwsgi.worker.0.delta_requests:1|c" | nc -w 1 -u localhost 8125
echo "uwsgi.worker.1.delta_requests:1|c" | nc -w 1 -u localhost 8125
echo "uwsgi.worker.0.avg_response_time:10|c" | nc -w 1 -u localhost 8125
echo "uwsgi.worker.1.avg_response_time:10|c" | nc -w 1 -u localhost 8125
Measurements in InfluxDB after emitting statsd metrics
> show measurements
name
alerta_alerts
cpu
disk
diskio
kernel
mem
processes
swap
system
uwsgi_worker_0_avg_response_time
uwsgi_worker_0_core_0_write_errors
uwsgi_worker_0_delta_requests
uwsgi_worker_1_avg_response_time
uwsgi_worker_1_core_0_write_errors
uwsgi_worker_1_delta_requests
My expectation is telegraf should drop the measurement which matches the pattern but it is not
First, are you really using InfluxDB 1.1.1? That’s a very old version, and an upgrade there might help.
I see that telegraf is creating the measurements by replacing the .
with _
so have you tried adding
namedrop = ["uwsgi_worker_*_core_*_write_errors", "uwsgi_worker_*._espawns"]
to your config and see if it then drops those? I haven’t had time to check the code to see if it evaluates the namedrop rule before or after converting the .
s too _
s but it’s worth checking out.
Best Regards,
dg
@davidgs/@daniel that was error in test setup. We are actually running influxdb 1.7.6 it was corrected inital test is working fine. But we will do through check on actual metrics. Can you please help me with
how to speed up drop measurement. i have 13 million measurements to delete. each measurement taking 2 min to drop. we are running in nvm ssd and have good ram and cpu.
@davidgs/@daniel please let me know how can i speed up measurements drop. we are using influxdb 1.7.6 .
Hi @hellobhaskar,
Is it an option to duplicate the “good” measurements to a new database ?
And then drop the database with the 13.000.000 measurements ?
Then continue working on the new database or create the “old” one again and copy the data back ?
And ofcourse as David suggested , replace the . with _ in the namedrop …
@MarcV/ @davidgs/ @daniel unfortuantely that is too tedious as we have tons of measurements.
Can you please tell if i do
delete * from /mymeasurementregex/;
will drop points as well as measurements ?
our immediate problem is chronograf/grafana freezes when populating measurment list. We have implemented namedrop suggestion.
