By default a Telegraf installation has the [[outputs.influxdb]] plugin enabled.
I’d like to disable that plugin and enable a different one ([[outputs.http]]).
The practice we usually like to employ in cases like this is not changing the original config file (i.e /etc/telegraf/telegraf.conf) but only applying specific overrides in the .d/ config directory; that way we don’t have to store huge configuration files in our code base that no one understands but only the diff that applies our configuration.
Is there any way to disable outputs.influxdb from a file in .d (e.g /etc/telegraf/telegraf.d/my_config.conf) ?
