Disabling or setting session idle timeout
Hello all,
I am currently asking if there is any way to configure InfluxDB so that there is no idle timeout? Such as if i left InfluxDB alone for a few hours , it wouldn’t log me out
Thankss!
Hi @KaiJ17,
I am not sure if I know off the top of my head. I will ask when everyone is back tommorow. The only one i can think of is an InfluxDB server config paramterL
@Jay_Clifford Thank you! ill try it out myself too!
I bumped at this post since I wanted to do the same. In order to set longer timeout there are two settings that need to be configured:
Steps:
In /etc/influxdb/config.toml file add:
session-renew-disabled = true
session-length = 1440 # session renewal after 1 day
Restart influxdb:
systemctl restart influxd
Check if configuration is applied:
influx server-config | grep -i session
Tested on:
InfluxDB 2.6.1. OSS
OS: Fedora 36
Best regards,
ldrascic
Where can i find this config on Windows?
Yes i know, “why do you even use Windows?” because i’m too dumb for linux
@Philip_Reutzel you edit or create your own custom config file and place it where you launch inlfuxDB:
InfluxDB configuration options | InfluxDB OSS 2.7 Documentation (influxdata.com)
In my case : C:\Program Files\InfluxData\influxdb\influxdb2_windows_amd64
Hey,
I have a docker deployment of influxDB. How to make this configuration changes accordingly?
