Help: guys ,how to set influxdb admin token session time? docker
I m using docker install influxdb, however I can’t find the way to change defult admin session time. my admin keep login me out…
  • DOCKER_INFLUXDB_INIT_RETENTION=1w
    • DOCKER_INFLUXDB_SESSION_LENGTH=6000
Hello @Grand_City,
Welcome!
Is that in the environment in your docker compose?
You might also need to change it in your influxdb config
