I am attempting to migrate some existing Influxdb databases I’ve been using on a another Raspberry Pi to a new system. In the new system I have Influxdb version 1.7.9 running. I can create databases that show up in Cronograf, but I cannot find those databases or tables in the Raspberry Pi directory /var/lib/influxdb.
I am looking for the directories where new Influxdb databases are stored on a Raspberry Pi.
My influxdb.conf file (in /etc/influxdb/) has:
[meta] # Where the metadata/raft database is stored
dir = “/var/lib/influxdb/meta”
[data]
`# The directory where the TSM storage engine stores TSM files.
dir = “/var/lib/influxdb/data”
# The directory where the TSM storage engine stores WAL files.
wal-dir = “/var/lib/influxdb/wal”
My /var/lib/influxdb/data and /var/lib/linfluxdb/wal directories have (moved from previous installation):
_internal
boiler
openhab_db
telegraf
The owner of those directories, for reference, is influxdb with Rights = rwxr-xr-x
In Cronograf the databases that are listed are:
_internal
pimilifeuptermpature
sinus
pi@raspberrypi:~ $ influx
Connected to http://localhost:8086 version 1.7.9
InfluxDB shell version: 1.7.9
show databases
name
telegraf
_internal
pimylifeuptemperature
sinus
These latter 2 were created as tests to try to identify where the databases/tables are stored. As you can see they are not listed in the /var/lib/influxdb directory.
pi@raspberrypi:~ $ sudo find / -type d -name ‘sinus’
