I have influx running on an AWS instance. The instance restarted. And I checked the influx data through influx cli and the previous records were not there. But, I checked it on the wal and data, the tsm files are there. Can anyone please tell me what’s going on here?
@avellable Hi! Can you share your influxdb version, your influxdb config file, and the output of tree /var/lib/influxdb/?
$ influx --version
InfluxDB shell version: 1.2.2
$ sudo tree /var/lib/influxdb/
/var/lib/influxdb/
|-- data
| `-- _internal
| `-- monitor
| `-- 1
|-- meta
| `-- meta.db
`-- wal
`-- _internal
`-- monitor
`-- 1
`-- _00001.wal
But I moved these defaults as,
[meta]
# Where the metadata/raft database is stored
dir = "/opt/influx/meta"
[data]
# The directory where the TSM storage engine stores TSM files.
dir = "/opt/influx/data"
# The directory where the TSM storage engine stores WAL files.
wal-dir = "/opt/influx/wal"
And the tree there looks ok
$ sudo tree /opt/influx/
/opt/influx/
|-- data
| |-- _internal
| | `-- monitor
| | |-- 176
| | | |-- 000000004-000000003.tsm
| | | |-- 000000006-000000002.tsm
| | | `-- 000000007-000000001.tsm
| | `-- 183
| |-- dbname1
195 directories, 227 files
I have the same issue when TSI is enabled. When using the default index-version it works as expected.
$ influx --version
InfluxDB shell version: 1.3.0
$ ls -lR /var/lib/influxdb/data/rrdev/data_export/
/var/lib/influxdb/data/rrdev/data_export/:
total 0
drwxr-xr-x 4 root root 136 Jul 9 18:00 23
/var/lib/influxdb/data/rrdev/data_export/23:
total 4
-rw-r--r-- 1 root root 873 Jul 9 18:00 000000003-000000002.tsm
drwxr-xr-x 4 root root 136 Jul 9 17:23 index
/var/lib/influxdb/data/rrdev/data_export/23/index:
total 4
-rw-r--r-- 1 root root 0 Jul 9 17:23 L0-00000001.tsl
-rw-r--r-- 1 root root 403 Jul 9 17:23 MANIFEST
$ ls -lR /var/lib/influxdb/wal/rrdev/data_export/
/var/lib/influxdb/wal/rrdev/data_export/:
total 0
drwx------ 3 root root 102 Jul 9 18:17 23
/var/lib/influxdb/wal/rrdev/data_export/23:
total 0
-rw-r--r-- 1 root root 0 Jul 9 18:17 _00004.wal
$ influx_inspect export -database rrdev -retention data_export -datadir /var/lib/influxdb/data -waldir /var/lib/influxdb/wal -out ~/export.txt && cat ~/export.txt
writing out tsm file data for rrdev/data_export...complete.
writing out wal file data for rrdev/data_export...complete.
# INFLUXDB EXPORT: 1677-09-21T00:12:43Z - 2262-04-11T23:47:16Z
# DDL
CREATE DATABASE rrdev WITH NAME data_export
# DML
# CONTEXT-DATABASE:rrdev
# CONTEXT-RETENTION-POLICY:data_export
# writing tsm data
data_export,measurement_name=sensordata commit_ms=0i 1499620733593000000
data_export,measurement_name=sensordata commit_ms=3545i 1499622533593000000
data_export,measurement_name=sensordata exported_time=0 1499620733593000000
data_export,measurement_name=sensordata exported_time=1.499622544278e+12 1499622533593000000
data_export,measurement_name=sensordata num_measurements=0i 1499620733593000000
data_export,measurement_name=sensordata num_measurements=52174i 1499622533593000000
data_export,measurement_name=sensordata query_ms=0i 1499620733593000000
data_export,measurement_name=sensordata query_ms=5786i 1499622533593000000
data_export,measurement_name=sensordata total_ms=0i 1499620733593000000
data_export,measurement_name=sensordata total_ms=10676i 1499622533593000000
data_export,measurement_name=sensordata write_bytes=0 1499620733593000000
data_export,measurement_name=sensordata write_bytes=1.6282468e+07 1499622533593000000
data_export,measurement_name=sensordata write_ms=0i 1499620733593000000
data_export,measurement_name=sensordata write_ms=4600i 1499622533593000000
# writing wal data
$ curl -s 'http://localhost:8086/query' --data-urlencode "db=rrdev" --data-urlencode "q=SELECT * FROM data_export.data_export"
{"results":[{"statement_id":0}]}
Would have expected to get results from the last query with curl, but got instead an empty result set.
InfluxDB is running inside a docker container.
Here is the influxdb config file:
reporting-disabled = true
bind-address = ":8088"
[meta]
dir = "/var/lib/influxdb/meta"
retention-autocreate = false
logging-enabled = true
[data]
dir = "/var/lib/influxdb/data"
wal-dir = "/var/lib/influxdb/wal"
index-version = 'tsi1'
query-log-enabled = false
cache-max-memory-size = 536870912
cache-snapshot-memory-size = 26214400
cache-snapshot-write-cold-duration = "10m0s"
compact-full-write-cold-duration = "4h0m0s"
max-series-per-database = 1000000
max-values-per-tag = 100000
trace-logging-enabled = false
[coordinator]
write-timeout = "60s"
max-concurrent-queries = 0
query-timeout = "60s"
log-queries-after = "10s"
max-select-point = 0
max-select-series = 0
max-select-buckets = 0
[retention]
enabled = true
check-interval = "30m0s"
[shard-precreation]
enabled = true
check-interval = "10m0s"
advance-period = "30m0s"
[admin]
enabled = false
bind-address = ":8083"
https-enabled = false
https-certificate = "/etc/ssl/influxdb.pem"
[monitor]
store-enabled = false
store-database = "_internal"
store-interval = "10s"
[subscriber]
enabled = true
http-timeout = "30s"
insecure-skip-verify = false
ca-certs = ""
write-concurrency = 40
write-buffer-size = 1000
[http]
enabled = true
bind-address = ":8086"
auth-enabled = true
log-enabled = false
write-tracing = false
pprof-enabled = true
https-private-key = ""
max-row-limit = 1000000
max-connection-limit = 0
shared-secret = ""
realm = "InfluxDB"
unix-socket-enabled = false
bind-socket = "/var/run/influxdb.sock"
[continuous_queries]
log-enabled = false
enabled = true
run-interval = "1s"
