Delete series with numeric names
I’ve made a bit of a error while experimenting with InfluxDB and Telegraf’s csv file and have managed to create a bunch of measurements with numeric names. Which I’m unable to remove with the drop command
> drop measurement 99983224
ERR: error parsing query: found 99983224, expected identifier at line 1, char 18`
I’ve also tried
> drop measurement "99983224"
How do I get rid of these measurements?
Version: InfluxDB 1.7.4
Kind regards
Richard Lucas
Hi ,
here it works , you could try delete from “99983224”
if drop measurement does not work
 > insert 99983224 field1=5
 > select * from "99983224"
 time                field1
 1551721147552674690 5
Hi Marc,
Thanks - that works a dream with the 2 steps - delete anything in them, and then drop the measurement.
I hadn’t realised that I needed to do both.
Thanks for taking the time to help.
Richard
One of them is enough :slight_smile: delete everything/anything removes the measurement , it is strange the drop didn’t work for you , i have 1.7.4 on linux
Do you have an idea what the problem could be here ? …
Csv problem telegraf
I have no idea what has happened over night, except we restarted our servers, and now the drop measurement command works as you demo’d.
I piped the list of numerical names into a file and then passed that into this little bash script that executed a influx command to drop the metric.
#!/usr/bin/env bash
for met in $(cat "${1}"); do
    echo $met
    ./monitoring/influxdb/influx -port 8086 -database="telegraf" -execute "drop measurement \"${met}\""
done
