Delete series Chornograf Request failed with status code 400
I try to delete some points from a measurement via Chronograf and compared this with the influx commandline:
Chronograf SELECT:
USE homeassistant
# Request failed with status code 400
# USE looks like not supported in Chronograf
SELECT * from "%" where entity_id='dht22_humidity' and time < '2020-12-19T15:00:00Z'
# Database name required
# So use the command below instead:
SELECT * from "homeassistant"."autogen"."%" where entity_id='dht22_humidity' and time < '2020-12-19T15:00:00Z'
# Correct output
influxd terminal SELECT:
USE "homeassistant"
# Using database homeassistant
# name: %
# time                attribution_str device_class_str domain entity_id      friendly_name friendly_name_str i# con icon_str          value
# 1608314274417447936                                  sensor dht22_humidity 22            DHT22 Humidity         mdi:water-percent 12
# 1608314289059613952                                  sensor dht22_humidity 22            DHT22 Humidity         mdi:water-percent 11
# 1608314443618347776                                  sensor dht22_humidity 22            DHT22 Humidity         mdi:water-percent 12
# Same output
Chronograf DELETE:
DELETE from "homeassistant"."autogen"."%" where entity_id='dht22_humidity' and time < '2020-12-19T15:00:00Z'
# Question: What is the correct DELETE syntax in Chronograf?
Influxd terminal DELETE:
USE homeassistant
# ERR: error parsing query: retention policy not supported at line 1, char 1
DELETE from "%" where entity_id='dht22_humidity' and time < '2020-12-19T15:00:00Z'
# Works
How can I run the same DELETE command in Chronograf?
Hello @Erriez,
I’m not sure. I thought you should be able to. Can you please submit an issue?
Chronograf issue created:
