Overview
influxdb-python: v.5.2.0 -
python: version 3.4.3 - Machine: Window 10 + Windows subsystem for Linux (WSL)
Scenario
- Configured
udpto be accessed via8089 - InfluxDB running via Powershell
- Python Script executed via WSL
Code
from influxdb import InfluxDBClient
def main():
client = InfluxDBClient(host='localhost',database='example',use_udp=True, udp_port=8089)
json_body = {
"tags": {
"host": "server01",
"region": "us-west"
"time": "2009-11-10T23:00:00Z",
"points": [{
"measurement": "cpu_load_short",
"fields": {
"value": 0.64
try:
client.send_packet(json_body)
except Exception as e:
raise e
if __name__ == '__main__':
main()
Output
Instead of saving the information in the example database the information is stored in a newly created database called udp.
No measurements are created in example
All values are available in udp
