Hello Team,
I am trying to add data with below curl command but it gives error
echo -e “usage,host=influxdb,cluster=louis,pl_instance_name=2i-retegas,gitlabusage=“Thu Oct 20 13:48:02 2022”,jenkinsusage=“Fri Jan 20 06:52:05 2023”,sonarqubeusage=“Mon Oct 17 11:52:20 2022”,nexususage=“Not Use 00 00:00:00 0000” lastused=averagetime” | curl -X POST --data-binary @- https://influxdb-.com/write?db=usage
error
{“error”:“unable to parse ‘usage,host=influxdb,cluster=louis,pl_instance_name=2i-retegas,gitlabusage=Thu Oct 20 13:48:02 2022,jenkinsusage=Fri Jan 20 06:52:05 2023,sonarqubeusage=Mon Oct 17 11:52:20 2022,nexususage=Not Use 00 00:00:00 0000 lastused=averagetime’: invalid field format”}
can you please guide what I am missing here I tried to escape space with \ but no luck
Regards,
SAM
