Hi all
I feel like I’m getting somewhere but hitting a brick wall on last meters.
- Trying to import CSV to influxdb with Telegraf File plugin. Idea is to manually place .csv into a folder which is monitored by telegraf.
- Tested the connection to database with hard drive-plugin and it showed ok in Data Explorer
- Only column names are showing up in Data Explorer, no data is being transferred and I cant find anything wrong with config, date format or anything else.
- CSV in question should be ok. Excel opened it up without problems and MSSQL could also import it. Using V1 shell, no data can be seen in bucket
- If there’s better way to achieve this or a way to test it in command line, I’m happy to change to whatever works.
Debug mode on:
2023-07-17T04:18:51Z I! Loading config: /etc/telegraf/telegraf.conf
2023-07-17T04:18:51Z I! Starting Telegraf 1.27.2
2023-07-17T04:18:51Z I! Available plugins: 237 inputs, 9 aggregators, 28 processors, 23 parsers, 59 outputs, 4 secret-stores
2023-07-17T04:18:51Z I! Loaded inputs: file
2023-07-17T04:18:51Z I! Loaded aggregators:
2023-07-17T04:18:51Z I! Loaded processors:
2023-07-17T04:18:51Z I! Loaded secretstores:
2023-07-17T04:18:51Z I! Loaded outputs: influxdb_v2
2023-07-17T04:18:51Z I! Tags enabled: dc=finland host=tupu
2023-07-17T04:18:51Z I! [agent] Config: Interval:10s, Quiet:false, Hostname:"tupu", Flush Interval:10s
2023-07-17T04:18:51Z D! [agent] Initializing plugins
2023-07-17T04:18:51Z D! [agent] Connecting outputs
2023-07-17T04:18:51Z D! [agent] Attempting connection to [outputs.influxdb_v2]
2023-07-17T04:18:51Z D! [agent] Successfully connected to outputs.influxdb_v2
2023-07-17T04:18:51Z D! [agent] Starting service inputs
2023-07-17T04:19:01Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
“Buffer fullness” keeps repeating.
Config, inputs.file -part
[[inputs.file]]
files = ["/home/pi/database/Log_2023.csv"]
data_format = "csv"
csv_header_row_count = 1
csv_skip_rows = 0
csv_column_names = ["Row", "Sensor", "Date time", "Cumulative chip Count", "1h count Frequency", "24h Count", "Moisture", "Temperature T", "P2_Rough", "P2_Calibrated", "F0", "Fdif", "Tdif", "DeltaF", "P", "A", "B", "C", "D", "E", "F", "N", "T1", "T2", "T3", "DevResults", "CustomerID1", "CustomerID2", "CustomerID3", "Misc1", "Misc2", "Misc3"]
# trying ; and ,
csv_delimiter = ";"
csv_trim_space = true # Set this to true if you want to trim leading and trailing spaces in the fields
csv_tag_overwrite = false
csv_measurement_column = "" # Leave this empty if you want to use the default measurement name ("file")
csv_timestamp_column = "Date time" # Specify the column containing the timestamp
csv_timestamp_format = "2006-1-2 15:04:05" # Format of the timestamp column
csv_timezone = "Europe/Helsinki"
csv_skip_errors = false
Few rows of the .csv in question.
Row;Sensor;Date time;Cumulative chip Count;1h count Frequency;24h Count;Moisture;Temperature T;P2_Rough;P2_Calibrated;F0;Fdif;Tdif;DeltaF;P;A;B;C;D;E;F;N;T1;T2;T3;DevResults;CustomerID1;CustomerID2;CustomerID3;Misc1;Misc2;Misc3;
1;Engine 1;2023-3-13 13:13:36;3;0;0;0.0;1372.0;0.0;0.0;0.0;0.0;0.0;0.0;0.1;-0.007;-0.01;0.00042;0.0125;0.0003;8.58;1.0;50.0;55.0;60.0;FALSE;OM-Finland;Autotalli 1;Testipenkki 1;;12333;;
2;Engine 2;2023-3-13 13:13:36;0;0;0;0.0;19.9;0.0;0.0;0.0;0.0;0.0;0.0;0.1;-0.007;-0.01;0.00042;0.0125;0.0003;8.58;1.0;50.0;55.0;60.0;FALSE;OM-Finland;Pieksämäki 1;Turbiini 1;;;;
3;Engine 3;2023-3-13 13:13:36;0;0;0;0.0;;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;FALSE;OM-Finland;Jääkiekkohalli 5;Mopo 3;45;;;
4;Engine 1;2023-3-13 13:16:35;3;0;0;0.0;1372.0;0.0;0.0;0.0;0.0;0.0;0.0;0.1;-0.007;-0.01;0.00042;0.0125;0.0003;8.58;1.0;50.0;55.0;60.0;FALSE;OM-Finland;Autotalli 1;Testipenkki 1;;12333;;
5;Engine 2;2023-3-13 13:16:35;0;0;0;0.0;20.0;0.0;0.0;0.0;0.0;0.0;0.0;0.1;-0.007;-0.01;0.00042;0.0125;0.0003;8.58;1.0;50.0;55.0;60.0;FALSE;OM-Finland;Pieksämäki 1;Turbiini 1;;;;
6;Engine 3;2023-3-13 13:16:35;0;0;0;0.0;;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;0.0;FALSE;OM-Finland;Jääkiekkohalli 5;Mopo 3;45;;;
syslog file excerpt, does this open up anything?
Jul 16 22:47:39 tupu systemd[1]: Started Session 13 of user pi.
Jul 16 22:47:46 tupu influxd-systemd-start.sh[532]: ts=2023-07-16T19:47:46.316115Z lvl=error msg="Unable to write gathered points" log_id=0j3i5a>Jul 16 22:47:56 tupu influxd-systemd-start.sh[532]: ts=2023-07-16T19:47:56.303885Z lvl=error msg="Unable to write gathered points" log_id=0j3i5a>Jul 16 22:47:59 tupu systemd[1]: session-13.scope: Succeeded.
Jul 16 22:47:59 tupu systemd[1]: session-13.scope: Consumed 1.640s CPU time.
