Hi all, I’ve used Telegraf and InfluxDb for a couple of years now to collect Windows Performance counters, a new requirement has popped up which means that I need to collect and send data regarding data in backlog (could be queues, files in directories etc), so far so good, I have services that collect all this information and dump them to a CSV file. Now here comes my problem:
The CSV:s looks something like this:
name,count,protocol,timestamp
Internal API,44,ServiceBus,2023-11-16 18:51:11
Incoming,0,SMB,2023-11-16 18:51:11
External API,0,ServiceBus,2023-11-16 18:51:11
Flatfiles,2,SMB,2023-11-16 18:51:11
Telegraf has been configured as:
[global_tags]
env = "TEST"
[agent]
interval = "10s"
round_interval = true
metric_buffer_limit = 1000
flush_buffer_when_full = true
collection_jitter = "0s"
flush_interval = "5s"
flush_jitter = "0s"
debug = true
quiet = false
logfile = "C:\\AppLogs\\Telegraf\\Telegraf.log"
hostname = ""
[[outputs.influxdb]]
urls = ["https://influxdb.test.internal:15970/"]
database = "testlog"
timeout = "5s"
username = "logger"
password = "xxxxxxxxx"
[[outputs.file]]
files = ["stdout", "C:\\temp\\metrics.out"]
data_format = "json"
[[inputs.file]]
files = ["C:\\QueueCounterData\\TelegrafDump-OP.csv"]
data_format = "csv"
csv_header_row_count = 1
csv_tag_columns = ["name","protocol"]
csv_tag_overwrite = true
csv_timestamp_column = "timestamp"
csv_measurement_column = "count"
csv_timestamp_format = "2006-01-02 15:04:05"
If I run telegraf using
telegraf.exe -config .\telegraf.conf --test
It shows me the contents of the CSV, but if I run it without the test parameter it does run, but all I can see in the logs is:
2023-11-16T17:36:30Z D! [outputs.file] Buffer fullness: 0 / 1000 metrics
2023-11-16T17:36:30Z D! [outputs.influxdb] Buffer fullness: 0 / 1000 metrics
And nothing ever gets written to either the output file or to influx.
I’ve tried fiddling around a bit with the csv settings, but to no avail.
Anyone of you guys who knows where I’m going completely wrong here?
