I’ve spent some time trying to understand how to use json_v2 with my mqtt_consumer flow, without any luck. ![]()
My json payload looks like this:
"model": "Bresser-3CH",
"id": 130,
"channel": 1,
"battery_ok": 1,
"temperature_C": 12.66667,
"humidity": 19,
"mic": "CHECKSUM",
"protocol": "Bresser Thermo-/Hygro-Sensor 3CH",
"rssi": -61,
"duration": 1753996
Of these, the following are tags:
- channel
- id
- model
The following are the fields I’m interested in:
- humidity
- temperature_C
- rssi
- battery_ok
The rest (protocol, mic, duration) are not interesting and if possible I’d like to ignore them.
I have this setup using the json data format, and it works OK:
[[inputs.mqtt_consumer]]
servers = ["tcp://127.0.0.1:1883"]
topics = [
"home/OpenMQTTGateway_lilygo_rtl_433_ESP/RTL_433toMQTT/#"
topic_tag = "topic"
qos = 0
data_format = "json"
username = "telegraf"
password = "notmyrealpassword"
tag_keys = [ "model", "id", "channel" ]
json_string_fields = []
topic = "+/+/+/+/+/+"
tags = "site/_/_/model/channel/device_id"
I’m not even sure the topic parsing is relevant with this setup?
I had tried with something like this, but getting an error message that my JSON was invalid, which surprised me! What is wrong with below?
topics = [
# Real topic structure
# "home/OpenMQTTGateway_lilygo_rtl_433_ESP/RTL_433toMQTT/Bresser-3CH/1/130",
topic_tag = "topic"
qos = 0
data_format = "json_v2"
path = "humidity"
type = "int"
path = "battery_ok"
type = "int"
path = "temperature_C"
type = "float"
path = "rssi"
type = "int"
[[inputs.mqtt_consumer.json_v2.tag]]
path = "model"
path = "id"
type = "int"
path = "channel"
type = "int"
And oh, in case it’s interesting, here’s my output:
[[outputs.influxdb_v2]]
urls = ["http://localhost:8086"]
token = "$INFLUX_TOKEN"
organization = "foobar"
bucket = "metrics"
