Hi, I am trying to use geojson information to be able to show a forecast temperature data graph.
But I am not able to find the correct telegraf config.
The geojson can be found here:
https://dataset.api.hub.geosphere.at/v1/timeseries/forecast/nowcast-v1-15min-1km?parameters=t2m&lat_lon=48.18790304225732%2C%2016.4005100685933&forecast_offset=0&output_format=geojson
I wanted to use timestamps and the data arrays to be used.
Here’s my config:
[[inputs.http]]
One or more URLs from which to read formatted metrics
urls = [“https://dataset.api.hub.geosphere.at/v1/timeseries/forecast/nowcast-v1-15min-1km?parameters=t2m&lat_lon=48.18790304225732%2C%2016.4005100685933&forecast_offset=0&output_format=geojson”]
data_format = “json_v2”
[[inputs.http.json_v2]]
measurement_name = “nowcastv1”
[[inputs.http.json_v2.object]]
path = “@this”
timestamp_key = “timestamps”
timestamp_format = “rfc3339”
disable_prepend_keys = true
[inputs.file.json_v2.object.fields]
key = “float”
path = “@this.features.0.properties.parameters.t2m.data”
