Dear All,
I just noticed, that when I try to put a long(ish) query on the clipboard, i.e. Copy
, only the first few lines and the last lines are actually copied, so when I paste the content in another application, i.e. Notepad (but I tried others as well), I can see the first few lines, the last few lines and three dots in between, like this:
tableGPSAccuracy = from(bucket: "home_assistant")
|> filter(fn: (r) => r["_measurement"] == "device_tracker.bernadett_mate10")
|> filter(fn: (r) => r["_field"] == "gps_accuracy")
|> drop(columns: ["_start", "_stop", "domain", "_measurement", "entity_id", "source", "_field"])
tableLatitude = from(bucket: "home_assistant")
…ResultTable = join(tables: {tTmp1: tableTmp1, tTmp2: tableTmp2}, on: ["_time"], method: "inner")
ResultTable |> yield()
I wonder if this is something specific to my setup (Windows 10 Pro 64, Firefox) or something generic.
Also, while we are on the subject, Cut doesn’t work for me either. I tried Ctrl-X
, Shift-Del
, and with the mouse in the local menu, none of them work. Any idea why?
