I want to copy an InfluxDB database (really I just want a few specific measurements) that exists on a server onto my local machine in order to write some Kapacitor alerts. I’m trying to follow the documentation, but I’m not getting the desired result.
First, I tried influxd backup then an influx -restore. Using this method, I see the series exist but no data at all. “SHOW SERIES” and “SHOW MEASUREMENTS” look exactly as they should, but if i “SELECT * FROM <any_measurement>” there is no result. There are 300ish measurements and all of the 25 or so that I checked have the same result.
Next I attempted to use the influx_inspect export + influx -import. This just took forever. I only have a 24 hour retention period, 1.2G total disk usage, but somehow it went through over 300mil lines and would’ve been more but I killed it after waiting for 3 hours. I query for my data to see if any of it succeeded. Using SHOW only about 50 of the 300 measurements appear. Using SELECT all my queries return no results. So I try to figure out another way to do it…
Next I took the output of influx_inspect and filtered it down to just a handful of measurements that I’m interested in. I import this using influx -import and completes quickly…excellent. However, to my dismay, the same behavior happens as before…I see all the series / measurements using SHOW but no data comes back using SELECT.
What’s happening?
Here’s some output of my commands…
start of the file I’m using:
root@cde25774ae6a:/tmp# head -n10 load.txt
# DML
# CONTEXT-DATABASE: ecl
# CONTEXT-RETENTION-POLICY: autogen
incoming_feed_dealers,host=InvDEVTE09Web01,metric_type=set value=3i 1498050000000000000
incoming_feed_dealers,host=InvDEVTE09Web01,metric_type=set value=3i 1498050010000000000
incoming_feed_dealers,host=InvDEVTE09Web01,metric_type=set value=3i 1498050020000000000
incoming_feed_dealers,host=InvDEVTE09Web01,metric_type=set value=3i 1498050030000000000
incoming_feed_dealers,host=InvDEVTE09Web01,metric_type=set value=3i 1498050040000000000
I’m importing the file:
root@cde25774ae6a:/tmp# influx -import -path=load.txt
2017/06/23 01:55:51 Processed 100000 lines. Time elapsed: 1.931504192s. Points per second (PPS): 51773
2017/06/23 01:55:53 Processed 200000 lines. Time elapsed: 4.032506818s. Points per second (PPS): 49596
2017/06/23 01:55:55 Processed 300000 lines. Time elapsed: 6.722230422s. Points per second (PPS): 44628
2017/06/23 01:55:59 Processed 400000 lines. Time elapsed: 10.407828107s. Points per second (PPS): 38432
2017/06/23 01:56:04 Processed 500000 lines. Time elapsed: 15.203411772s. Points per second (PPS): 32887
2017/06/23 01:56:13 Processed 600000 lines. Time elapsed: 24.275056461s. Points per second (PPS): 24716
2017/06/23 01:56:18 Processed 0 commands
2017/06/23 01:56:18 Processed 630266 inserts
2017/06/23 01:56:18 Failed 0 inserts
i can see series exist:
C02Q940XG8WM:~ bmoseley$ influx -database ecl -execute "show series limit 25"
key
db_query,db=mongo,host=InvStageAWeb01,metric_type=timing,table=incoming_feed,type=save
db_query,db=mongo,host=blayne.web.local,metric_type=timing,table=user_setting,type=find_first
db_query,db=mysql,host=InvDEVTE02App01,layer=unknown,metric_type=timing,success=1,table=incoming_feed_data_sets,type=select
db_query,db=mysql,host=InvDEVTE02Web01,layer=unknown,metric_type=timing,success=1,table=incoming_feed_data_sets,type=select
db_query,db=mysql,host=InvDEVTE02Web01,layer=unknown,metric_type=timing,success=1,table=incoming_feed_filter_sets,type=select
db_query,db=mysql,host=InvDEVTE02Web01,layer=unknown,metric_type=timing,success=1,table=incoming_feeds,type=select
db_query,db=mysql,host=InvDEVTE04Web01,layer=unknown,metric_type=timing,success=1,table=incoming_feed_data_sets,type=select
db_query,db=mysql,host=InvDEVTE09Web01,layer=unknown,metric_type=timing,success=1,table=incoming_feed_data_sets,type=select
db_query,db=mysql,host=InvStageAWeb01,layer=unknown,metric_type=timing,success=1,table=incoming_feed_data_sets,type=select
db_query,db=mysql,host=InvStageAWeb01,layer=unknown,metric_type=timing,success=1,table=incoming_feed_filter_sets,type=select
db_query,db=mysql,host=InvStageAWeb01,layer=unknown,metric_type=timing,success=1,table=incoming_feeds,type=select
alas, no data shows up:
influx -database ecl -execute "select * from db_query limit 10"
<no result>
