Copying data between measurements in different databases
Dear all,
I am new to using InfluxDB and apologize for my limited knowledge.
I have a database A with a certain number of measurements in it, and I want to copy one of these measurements in its entirety to database B.
What command should I use?
Please note that both database A and B are on localhost, but they are under different retention policies
Hello @Alexander_Var,
There isn’t a single command. How much data is in DB A?
Are you looking to continuously copy data?
If you’re looking to continuously copy data try:
If its a small amount of data you can query it with a client library and write it back to a new DB B.
