Convert telegraf.conf thats written to work with Influxdb v1 to v2?
I have this telegraf conf that collects metrics to a influxdbv1.
Can I easily convert this telegraf conf file so it works with influxdbv2?
I have added “bucket = xxxx” and “token = yyyy” to the conf file but that did not work :smiley: is there anyway to do this?
Please provide error messages that you received and your config file with any secrets removed.
Also take a look at the plugin README: https://github.com/influxdata/telegraf/tree/master/plugins/outputs/influxdb_v2
Hi @jpowers
This is what my conf file looks like. I placed it under /etc/telegraf/telegraf.d/telegraf_metrics.conf
When I stop/start the telegraf service it fails.
Did you set the org?
Ideally you look at why the service failed to start as you will get the exact error message:
journalctl --no-pager --unit telegraf
