Consistency level
Hi every one,
1-What does this command do?
-consistency 'any|one|-consistency ‘any|one|quorum|all’all’
I read about compaction level but as far as know it is automatically ! am i correct?
what is different between "any"and “all”?
and how about quorum?
2-why when i use “settings” command , username value is blank?
Setting Value
Host localhost:8086
Username
Database
RetentionPolicy
Pretty false
Format column
Write Consistency all
Thanks,
@Indeed_1
  1. That setting is specifically for clustered setups and has no meaning for a single node deployment (DOCS).
  2. To make the Username section be non blank you need to start the influx cli with the -username and -password options. The Database section will fill in if you start the cli with the -database directive or you use mydb.
@jackzampolin Thank you Jack :wink:
