I am trying to run some write group task using celery to write data inside influx.
My workers regularly encounters this error:
Traceback (most recent call last):
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 174, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/connection.py", line 95, in create_connection
raise err
File "/usr/local/lib/python3.10/site-packages/urllib3/util/connection.py", line 85, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 703, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 398, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 239, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File "/usr/local/lib/python3.10/http/client.py", line 1282, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.10/http/client.py", line 1328, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.10/http/client.py", line 1277, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.10/http/client.py", line 1037, in _send_output
self.send(msg)
File "/usr/local/lib/python3.10/http/client.py", line 975, in send
self.connect()
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 205, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 186, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f9101b27460>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/local/lib/python3.10/site-packages/celery/app/trace.py", line 451, in trace_task
R = retval = fun(*args, **kwargs)
File "/usr/local/lib/python3.10/site-packages/celery/app/trace.py", line 734, in __protected_call__
return self.run(*args, **kwargs)
File "/app/timeseries/tasks/seed.py", line 248, in seed
seed.service.insert_data(ts_fy.id, fy_df)
File "/app/timeseries/services/timeserie.py", line 112, in insert_data
self.ts_client.save_dataframe(timeserie.name, scient_df)
File "/app/timeseries/client.py", line 84, in save_dataframe
return self._wite_api.write(
File "/usr/local/lib/python3.10/site-packages/influxdb_client/client/write_api.py", line 371, in write
results = list(map(write_payload, payloads.items()))
File "/usr/local/lib/python3.10/site-packages/influxdb_client/client/write_api.py", line 369, in write_payload
return self._post_write(_async_req, bucket, org, final_string, payload[0])
File "/usr/local/lib/python3.10/site-packages/influxdb_client/client/write_api.py", line 517, in _post_write
return self._write_service.post_write(org=org, bucket=bucket, body=body, precision=precision,
File "/usr/local/lib/python3.10/site-packages/influxdb_client/service/write_service.py", line 63, in post_write
(data) = self.post_write_with_http_info(org, bucket, body, **kwargs) # noqa: E501
File "/usr/local/lib/python3.10/site-packages/influxdb_client/service/write_service.py", line 168, in post_write_with_http_info
return self.api_client.call_api(
File "/usr/local/lib/python3.10/site-packages/influxdb_client/api_client.py", line 341, in call_api
return self.__call_api(resource_path, method,
File "/usr/local/lib/python3.10/site-packages/influxdb_client/api_client.py", line 171, in __call_api
response_data = self.request(
File "/usr/local/lib/python3.10/site-packages/influxdb_client/api_client.py", line 386, in request
return self.rest_client.POST(url,
File "/usr/local/lib/python3.10/site-packages/influxdb_client/rest.py", line 304, in POST
return self.request("POST", url,
File "/usr/local/lib/python3.10/site-packages/influxdb_client/rest.py", line 217, in request
r = self.pool_manager.request(
File "/usr/local/lib/python3.10/site-packages/urllib3/request.py", line 78, in request
return self.request_encode_body(
File "/usr/local/lib/python3.10/site-packages/urllib3/request.py", line 170, in request_encode_body
return self.urlopen(method, url, **extra_kw)
File "/usr/local/lib/python3.10/site-packages/urllib3/poolmanager.py", line 376, in urlopen
response = conn.urlopen(method, u.request_uri, **kw)
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 813, in urlopen
[Previous line repeated 2 more times]
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 785, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/retry.py", line 592, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='localhost', port=8086): Max retries exceeded with url: /api/v2/write?org=scient&bucket=scient&precision=ns (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f9101b27460>: Failed to establish a new connection: [Errno 111] Connection refused'))
I have the same issue locally using docker and in my staging env using influxcloud from aws.
When i try to dig into the client code GitHub - influxdata/influxdb-client-python: InfluxDB 2.0 python client.
I see that my PoolManager is correctly setup to use a maxsize connection of 60 (default).
But when i debug i see that only 1 connection per pool is created and reused but when the client is trying to open a new one i hit this ConnectionRefusedError.
Am i missing something regarding concurrency writing using the python client ?
Thanks in advance,
