Hi there, I’m couple of days new to TICK stack and love the experience playing around. Thanks for the awesome stack.
I’m trying to configure TSL for Telegraf Kafka client for both inputs and outputs.
I have generated certificates for Kafka and these are the steps:
#Step 1
keytool -keystore server.keystore.jks -alias localhost -validity 365 -genkey#Step 2
openssl req -new -x509 -keyout ca-key -out ca-cert -days 365
keytool -keystore server.truststore.jks -alias CARoot -import -file ca-cert
keytool -keystore client.truststore.jks -alias CARoot -import -file ca-cert#Step 3
keytool -keystore server.keystore.jks -alias localhost -certreq -file cert-file
openssl x509 -req -CA ca-cert -CAkey ca-key -in cert-file -out cert-signed -days 365 -CAcreateserial -passin pass:test1234
keytool -keystore server.keystore.jks -alias CARoot -import -file ca-cert
keytool -keystore server.keystore.jks -alias localhost -import -file cert-signed#Step4
keytool -importkeystore -srckeystore server.truststore.jks -destkeystore server.p12 -deststoretype PKCS12
openssl pkcs12 -in server.p12 -nokeys -out server.cer.pemkeytool -importkeystore -srckeystore server.keystore.jks -destkeystore client.p12 -deststoretype PKCS12
openssl pkcs12 -in client.p12 -nokeys -out client.cer.pem
openssl pkcs12 -in client.p12 -nodes -nocerts -out client.key.pem
I’m successfully using .jks for java clients.
Configured in outputs.Kafka
tsl_ca = “client.cer.pem”
tsl_cert = “server.cer.pem”
tsl_key = “client.key.pem”
insecure_skip_verify = true
which is not working.
On Telegraf restart, this is the error:
E! [agent] Failed to connect to output kafka, retrying in 15s, error was ‘could not load keypair server.cer.pem:/client.key.pem: tls: failed to parse private key’
What is happening? Can some one help? thanks
