I have installed telegraf and started service on my local linux machine and i wanted to send data to azure monitoring using “outputs.azure_monitor” output plugin in telegraf configuration file. can someone guide me what fields need to be changes in “outputs.azure_monitor” plugin considering telegraf is not installed on azure VM’s.
[[outputs.azure_monitor]]
Timeout for HTTP writes.
timeout = “20s”
Set the namespace prefix, defaults to “Telegraf/”.
namespace_prefix = “Telegraf/”
Azure Monitor doesn’t have a string value type, so convert string
fields to dimensions (a.k.a. tags) if enabled. Azure Monitor allows
a maximum of 10 dimensions so Telegraf will only send the first 10
alphanumeric dimensions.
strings_as_dimensions = false
Both region and resource_id must be set or be available via the
Instance Metadata service on Azure Virtual Machines.
Azure Region to publish metrics against.
ex: region = “southcentralus”
region = “”
The Azure Resource ID against which metric will be logged, e.g.
sorry, for late reply @Anaisdg . I have went through the document, and made changes as.
I have added AZURE_TENANT_ID,AZURE_CLIENT_ID,AZURE_CLIENT_SECRET in my environmental variables as per plugins page,
## Timeout for HTTP writes.
# timeout = “20s”
## Set the namespace prefix, defaults to “Telegraf/”.
# namespace_prefix = “Telegraf/”
## Azure Monitor doesn’t have a string value type, so convert string
## fields to dimensions (a.k.a. tags) if enabled. Azure Monitor allows
## a maximum of 10 dimensions so Telegraf will only send the first 10
## alphanumeric dimensions.
strings_as_dimensions = true
## Both region and resource_id must be set or be available via the
## Instance Metadata service on Azure Virtual Machines.
## Azure Region to publish metrics against.
## ex: region = “southcentralus”
region = "EastUS"
## The Azure Resource ID against which metric will be logged, e.g.
