Hi guys,
Did anyone come up with a working Kapacitor configuration for the case where Kapacitor runs on an AWS instance and Influx is running on influxcloud? Could you share a generic version of it?
Thanks!
@gonber You just need to set the [[influxdb]] urls = ["https://my-cloud-url:8086"] to point your self hosted kapacitor at the database. There should be no issues with this configuration. Are you having trouble connecting to your cloud instance?
Thanks @jackzampolin. For future reference, adding to your info:
- set âkapacitor-hostnameâ to your visible AWS instance IP address
- make sure the AWS instance youâre running Kapacitor on is assigned a security group with an inbound rule that looks like "custom tcp rule, tcp, 9090, /32
- donât forget the url (as mentioned by @jackzampolin) should be âhttpsâ and not âhttpâ
