Hi!
I’m new to TICK and recently I am stuck on a simple task:
to show data from temperature measurements from various weather stations in Grafana in GeoLoop plugin.
As for timeseries data, I need to restructure existing datasets in InfluxDb:
show measurements name: measurements name ---- meteo_01 meteo_02 meteo_03 select * from meteo_01 limit 3 name: meteo_01 time dew_point hum humint insol pressure rain temp tempint wind wind_dir ---- --------- --- ------ ----- -------- ---- ---- ------- ---- -------- 2015-06-01T14:56:01Z 14 46 49 1015.7 0 26.5 26.3 0 8 2015-06-01T15:26:01Z 14.6 50 49 1015.5 0 25.8 26.7 0 13 2015-06-01T15:56:01Z 15.3 55 50 1015.5 0 24.9 26.9 0 13
Since I miss any tag in all meteo_* measurements, I was about to use continuous query to write them into new measurment and adding the tag location with that.
Unfortunately, my simple solution does not work:
SELECT INTO “geo_temp” ‘hill_top’ as location, mean(temp) FROM “meteo_01” WHERE …
since such operations with tags are not allowed (ERR: invalid expression type: *influxql.StringLiteral).
I am curious what it is the most straightforward way to do it – is that a batch TICKscript??
Any examples would be appreciated…
