I’m currently trying to get this example running using the docker tick stack.
If I change the kapacitor.conf to add the UDF, the Kapacitor docker container just stops immediately and a ping to http://localhost:9092/kapacitor/v1/ping no longer results in a 204.
My UDF config:
[udf.functions]
[udf.functions.tTest]
prog = "/usr/bin/python2"
args = ["-u", "/tmp/kapacitor_udf/ttest.py"]
timeout = "10s"
[udf.functions.tTest.env]
PYTHONPATH = "/tmp/kapacitor_udf/kapacitor/udf/agent/py"
Executing ./sandbox.bat enter kapacitor to enter the cli shows that no Python seems to be installed as the folder /usr/bin/python2 does not exist.
Also no log file is placed in /var/logs/kapacitor/
Is my configuration wrong? Or are there other ways to fix this issue?
