i have centos 7 box & as soon as influxdb started on the box the load avg goes up & the grafana page does not show the graphs
service seems running
● influxdb.service - InfluxDB is an open-source, distributed, time series database
Loaded: loaded (/usr/lib/systemd/system/influxdb.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2019-02-06 22:18:48 PST; 20min ago
Docs: https://docs.influxdata.com/influxdb/
Main PID: 10023 (influxd)
Tasks: 44
CGroup: /system.slice/influxdb.service
└─10023 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
var/log/messages have:
influxd: ts=2019-02-07T06:40:17.058639Z lvl=info msg="Write failed" log_id=0DTeaFHG000 service=write shard=418 error="[shard 418] error opening memory map for file /var/lib/influxdb/data/telegraf/autogen/418/000010129-000000001.tsm: mmapAccessor: invalid indexStart"
influxd: ts=2019-02-07T06:39:55.218679Z lvl=error msg="[500] - \"timeout\"" log_id=0DTeaFHG000 service=httpd
i started & enable httpd & the load now coming down
But i still see:
influxd: ts=2019-02-07T06:59:32.763939Z lvl=error msg="[500] - \"[shard 418] error opening memory map for file /var/lib/influxdb/data/telegraf/autogen/418/000010129-000000001.tsm: mmapAccessor: invalid indexStart\"" log_id=0DTgpCfW000 service=httpd
And i do not see the graphs
I think influx db has gown & need trimming … i am not sure how to do that & how can i tell it to save 30 days data only say…
thanks
