Am attempting to export some data and found a number of references to influx_inspect. Unfortunately I simply cannot find the command.
influx_inspect
-bash: influx_inspect: command not found
Platform is a Raspberry Pi 3 model B. I want to rename some topics and about the only way that I have found is export/fix/import
I have downloaded and compiled the code from source but the influx_inspect folder is basically empty except for a buildtsi folder
env GO111MODULE=on CGO_LDFLAGS="$(cat .cgo_ldflags)" go build -tags ‘assets libflux’ -ldflags " -X main.commit=1f1b1c492" -o bin/linux/influx_inspect ./cmd/influx_inspect
can’t load package: package ./cmd/influx_inspect: no Go files in /home/pi/go/src/github.com/influxdb/cmd/influx_inspect
make: *** [Makefile:87: bin/linux/influx_inspect] Error 1
The influx_inspect command is missing from the two Raspberry pi packages influxdb-client and influxdb
What happened to the command ?
Is there another way to achieve my objective without it ?
