What Grafana version and what operating system are you using?
Grafana * v8.5.2 (90701be19)
Indlux DB v2.2.0
Linux: Ubuntu 20.04.4 LTS -
What are you trying to achieve?
I have a variable to choose source of my data, i use Buckets() but i want to filter this to buckets that either matches a string with wildcard (*) or have a certain value in one of the measurements.
The amount of buckets availible is dynamic since i keep adding buckets with a script so the query must be dynamic to include all buckets in the search for matching ones.
How are you trying to achieve it?
I have tried all i can think of but it’s really hard to find guides and sources on flux to achieve what i’m trying to do. -
What happened?
I get either all or exact match on bucket if i set a name instead of Buckets() -
What did you expect to happen?
I want to select only buckets whos name starts with the string provided OR
I want to select only buckets that contains a certain value in a specified measurement
Either one of the above or both is ok. -
Can you copy/paste the configuration(s) that you are having problems with?
Buckets() -
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No it’s a Flux either restriction or ignorance from my side and i can’t seem to find guidance to learn what i need -
Did you follow any online instructions? If so, what is the URL?
I’ve scoured google for this matter but i can’t seem to find what i’m looking for
It is fine to create a new bucket with all the bucket names as a measurement and then select from the names with a wildcard from that bucket if this is possible
