I have bucketA where _value contain strings
I want to create a new label with map in bucketB when bucketA _value match with bucketB value
or just simply filter out from bucketB which are exists in bucketA
join is not an option as at the end i need to list those items from bucketB which are NOT in bucketA
so is this possible if yes what would be the best approach
Thanks!
