Im a newbie regarding Flux query language but Im willing to learn.
What I’ve got:
| table | _measurement | _field | _value | _start | _stop | _time | sensor | topic |
| 0 | tasmota | Power | 1952 | 2023-04-21T17:51:15.147Z | 2023-04-21T18:51:15.147Z | 2023-04-21T17:51:20.000Z | tasmota_waschingmachine | tele/tasmota_waschingmachine/SENSOR |
| 0 | tasmota | Power | 1944 | 2023-04-21T17:51:15.147Z | 2023-04-21T18:51:15.147Z | 2023-04-21T17:51:30.000Z | tasmota_waschingmachine | tele/tasmota_waschingmachine/SENSOR |
| 0 | tasmota | Power | 2050 | 2023-04-21T17:51:15.147Z | 2023-04-21T18:51:15.147Z | 2023-04-21T17:51:40.000Z | tasmota_waschingmachine | tele/tasmota_waschingmachine/SENSOR |
| 0 | tasmota | Power | 1845 | 2023-04-21T17:51:15.147Z | 2023-04-21T18:51:15.147Z | 2023-04-21T17:51:50.000Z | tasmota_waschingmachine | tele/tasmota_waschingmachine/SENSOR |
| 0 | tasmota | Power | 1840 | 2023-04-21T17:51:15.147Z | 2023-04-21T18:51:15.147Z | 2023-04-21T17:52:00.000Z | tasmota_waschingmachine | tele/tasmota_waschingmachine/SENSOR |
Every 10s I read the consumed power from my smart socket. I use Grafana to display the graphs over time.
What I want to achieve:
I want to calculate the consumption relative to the choosen time frame as a single value.
My approach:
time1int = int(v: v.timeRangeStart)
time2int = int(v: v.timeRangeStop)
time1float = float(v: time1int)
time2float = float(v: time2int)
span = (time2float - time1float)/3600.0
from(bucket: "SmartHome")
|> range(start: v.timeRangeStart, stop:v.timeRangeStop)
|> filter(fn: (r) =>
r._measurement == "tasmota" and
r._field == "Power" and
r.sensor == "tasmota_waschingmachine")
|> sum()
|> map(fn: (r) => ({ r with _value: (r._value*span)/1000.0}))
At first I calculate the seconds in the selected timeframe.
I convert it to float.
I calculate the duration in hours.
I read the data from the bucket, sum it up and calculate the consumption in kWh.
Obviously it doesnt work.
Please point me to the correct direction or show me an alternate approach. Any additional hints how to “echo” the variables or debug fluxQL are appreciated as well.
kind regards
Philipp
