I have script that select information from sql database and inject into influxdb.
I have several InfluxDB installations on old InfluxDB 1.3.7 and latest InfluxDB 1.5.1.
Part of influx dependent code here:
dbname = ‘oracle’
client = InfluxDBClient(host=‘localhost’,
port=8086,
database=dbname)
client.create_database(dbname)
class MySeries(SeriesHelper):
class Meta:
client = client
series_name = 'cpu'
fields = ['time',
'Field1',
'Field2',
'Field3',
'Field4']
tags = ['TaggedField1',
'TaggedField2',
'TaggedField3']
bulk_size = 330000
autocommit = True
def move_to_influx(query):
try:
with connection.cursor() as cursor:
cursor.execute(query)
for row in cursor:
date_str = str(row['Timestamp'])
dt_obj = datetime.strptime(date_str,
"%Y-%m-%d %H:%M:%S")
MySeries(time=dt_obj,
Field1=row['Field1'],
Field2=row['Field2'],
Field3=row['Field3'],
Field4=row['Field4'],
TaggedField1=row['TaggedField1'],
TaggedField2=row['TaggedField2'],
TaggedField3=row['TaggedField3'])
MySeries.commit()
finally:
connection.close()
When performing second iteration with MySeries.commit() script exits with error:
Traceback (most recent call last):
File "/home/ivanov/mysql_to_influx/lib/python3.5/site-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/home/ivanov/mysql_to_influx/lib/python3.5/site-packages/urllib3/connectionpool.py", line 357, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/lib/python3.5/http/client.py", line 1107, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.5/http/client.py", line 1152, in _send_request
self.endheaders(body)
File "/usr/lib/python3.5/http/client.py", line 1103, in endheaders
self._send_output(message_body)
File "/usr/lib/python3.5/http/client.py", line 936, in _send_output
self.send(message_body)
File "/usr/lib/python3.5/http/client.py", line 908, in send
self.sock.sendall(data)
BrokenPipeError: [Errno 32] Broken pipe
During handling of the above exception, another exception occurred:
File "/home/ivanov/mysql_to_influx/lib/python3.5/site-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/home/ivanov/mysql_to_influx/lib/python3.5/site-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/home/ivanov/mysql_to_influx/lib/python3.5/site-packages/urllib3/util/retry.py", line 357, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/home/ivanov/mysql_to_influx/lib/python3.5/site-packages/urllib3/packages/six.py", line 685, in reraise
raise value.with_traceback(tb)
chunked=chunked)
urllib3.exceptions.ProtocolError: ('Connection aborted.', BrokenPipeError(32, 'Broken pipe'))
File "marinflux.py", line 113, in <module>
main()
File "marinflux.py", line 108, in main
transit(query)
File "marinflux.py", line 81, in transit
AcctRc.commit()
File "/home/ivanov/mysql_to_influx/lib/python3.5/site-packages/influxdb/helper.py", line 146, in commit
rtn = client.write_points(cls._json_body_())
File "/home/ivanov/mysql_to_influx/lib/python3.5/site-packages/influxdb/client.py", line 468, in write_points
tags=tags, protocol=protocol)
File "/home/ivanov/mysql_to_influx/lib/python3.5/site-packages/influxdb/client.py", line 532, in _write_points
protocol=protocol
File "/home/ivanov/mysql_to_influx/lib/python3.5/site-packages/influxdb/client.py", line 312, in write
headers=headers
File "/home/ivanov/mysql_to_influx/lib/python3.5/site-packages/influxdb/client.py", line 252, in request
timeout=self._timeout
File "/home/ivanov/mysql_to_influx/lib/python3.5/site-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/home/ivanov/mysql_to_influx/lib/python3.5/site-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/home/ivanov/mysql_to_influx/lib/python3.5/site-packages/requests/adapters.py", line 490, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', BrokenPipeError(32, 'Broken pipe'))
Python script is executed on the same server InfluxDB 1.5.1.
When pointing script to another influx server, in my case 1.3.1, it runs without any problems up to end.
Maybe it is not the version issue but help please with ideas to further debug this exception.
Both InfluxDB configurations are the same.
