I just messed around with my system and had my test system collecting data for about one day. Unfortunately, the test system stopped working and I had to switch back to my original system. But now the question is, how to get the influxdb-data from the test system into the database of my original system?
I know about influxd backup, which also supports to limit the time frame. This would actually be what I am looking for. But since I cannot get my test system running, I cannot use this command to backup the data.
However, I have access to the drive of the test system. So I could just copy the files of /var/lib/influxdb/. But this would contain the full time frame and not just the missing one day of data.
The only thing I can come up with is:
- Backup influxdb directory on original system
- Copy influxdb directory from test system to original system
- Run
influxd backup ...to create the backup of the missing data - Copy backup of original system’s influxdb directory back on the original system
- Include the backup created in step 3
Of course stopping and starting of the influx service as needed in between.
Is there a better way to achieve the desired result?
By the way: I am using influxdb 1.8.3
Best regards
