Hi
I have a question about the "Telegaf, Influxdb & Grafana " solution
this solution doesn’t have an interface that facilitates the management??
Thank you
Hi
Thank you
I don’t think it does really. There used to be a web portal but i think that might have been for enterprise customers. A majority of it is done through the terminal. There is chronograf which you can use for dashboards. It also generates the TICK scripts for the alerts.
Hi Nadia ,
I know it is an old topic , but there is an interface that facilitates the management
for telegraf , influxdb , kapacitor and chronograf
in the InfluxDB v2.0.0-alpha
best regards ,
Marc
