Alerta Kapacitor no message available
Hey,
im trying to send alerts with alerta, but i get the error message:
no message available, how do i add a message to the alert?
thanks for the help.
Have you added the .message() part to your script/topic?
Yes i did:
Ok doke, Could you share your full tick script please?
var db = 'telegraf'
var rp = 'autogen'
var measurement = 'rabbitmq_queue'
var groupBy = []
var whereFilter = lambda: ("queue" == '*****************') AND isPresent("messages_ready")
var name = '************************'
var idVar = name
var message = ' {{.Level}} - test'
var idTag = 'alertID'
var levelTag = 'level'
var messageField = 'message'
var outputDB = 'chronograf'
var outputRP = 'autogen'
var outputMeasurement = 'alerts'
var triggerType = 'threshold'
var crit = 1
var data = stream
    |from()
        .database(db)
        .retentionPolicy(rp)
        .measurement(measurement)
        .groupBy(groupBy)
        .where(whereFilter)
    |eval(lambda: "messages_ready")
        .as('value')
var trigger = data
    |alert()
        .crit(lambda: "value" != crit)
        .message(message)
        .id(idVar)
        .idTag(idTag)
        .levelTag(levelTag)
        .messageField(messageField)
        .durationField(durationField)
        .post('***************')
        .header('Content-Type', 'application/json')
        .telegram()
        .chatId('***************')
        .parseMode('Markdown')
        .alerta()
        .environment('Test')
        .origin('kapacitor')
        .services()
        .message(message)
trigger
    |eval(lambda: float("value"))
        .as('value')
        .keep()
    |influxDBOut()
        .create()
        .database(outputDB)
        .retentionPolicy(outputRP)
        .tag('alertName', name)
trigger
    |httpOut('output')
Here
There’s a couple of other alert handlers there, do you get an alert and message to them as expected?
Yes i get the alerts to telegram.
i tried POST but it didnt work either (i have to remove it from the script)
righto, I’ve commented them out for now. I don’t have an alerta endpoint to test, but could you replace the bit between
var trigger = data
trigger
with this
    |alert()
        .message(message)
        .id(idVar)
        .idTag(idTag)
        .levelTag(levelTag)
       // .post('***************')
       // .header('Content-Type', 'application/json')
       // .telegram()
       // .chatId('***************')
       // .parseMode('Markdown')
        .alerta()
            .services()
            //.message(message)
As i say, I don’t have an alerta end point to test with. I do use a mixture of httpPost and post though and remember having some issues previously passing a message to them both.
TICK Script looks ok though so it should be working
Yes same here. i need to pass a Token-Type and a Token with the Post. but with .header() its not working.
The token and token prefix?
Hey, Sorry for the late reply. Yes but not for alerta for the HTTPPost.
