I 'm having an issue of getting alerts in alert history in chronograf.
I have created alert rule for cpu with threshold > 5 and task is enabled without handlers below is my tick script , i have written log
var db = ‘telegraf’
var rp = ‘autogen’
var measurement = ‘cpu’
var groupBy =
var whereFilter = lambda: (“cpu” == ‘cpu2’) AND isPresent(“usage_idle”)
var name = ‘cpu_alerts2’
var idVar = name
var message = ’ {{.ID}} {{.Name}}’
var idTag = ‘alertID’
var levelTag = ‘level’
var messageField = ‘message’
var durationField = ‘duration’
var outputDB = ‘chronograf’
var outputRP = ‘autogen’
var outputMeasurement = ‘alerts’
var triggerType = ‘threshold’
var crit = 10
var data = stream
|from()
.database(db)
.retentionPolicy(rp)
.measurement(measurement)
.groupBy(groupBy)
.where(whereFilter)
|eval(lambda: “usage_idle”)
.as(‘value’)
|log()
var trigger = data
|alert()
.crit(lambda: “value” > crit)
.stateChangesOnly()
.message(message)
.id(idVar)
.idTag(idTag)
.levelTag(levelTag)
.messageField(messageField)
.durationField(durationField)
.stateChangesOnly()
.log(‘/tmp/alerts.log’)
trigger
|eval(lambda: float(“value”))
.as(‘value’)
.keep()
|influxDBOut()
.create()
.database(outputDB)
.retentionPolicy(outputRP)
.tag(‘alertName’, name)
.tag(‘triggerType’, triggerType)
trigger
|httpOut(‘output’)
According to log data is receiving from influxdb to kapacitor , when kapacitor show no data points has been processed and also alerts are not gettting triggered please find below
DOT:
digraph chronograf-v1-b1d33782-2631-4218-8d45-f9a013dfa587 {
graph [throughput=“0.00 points/s”];
stream0 [avg_exec_time_ns=“0s” errors=“0” working_cardinality=“0” ];
stream0 → from1 [processed=“0”];
from1 [avg_exec_time_ns=“0s” errors=“0” working_cardinality=“0” ];
from1 → eval2 [processed=“0”];
eval2 [avg_exec_time_ns=“0s” errors=“0” working_cardinality=“0” ];
eval2 → alert3 [processed=“0”];
alert3 [alerts_inhibited=“0” alerts_triggered=“0” avg_exec_time_ns=“0s” crits_triggered=“0” errors=“0” infos_triggered=“0” oks_triggered=“0” warns_triggered=“0” working_cardinality=“0” ];
alert3 → http_out6 [processed=“0”];
alert3 → eval4 [processed=“0”];
http_out6 [avg_exec_time_ns=“0s” errors=“0” working_cardinality=“0” ];
eval4 [avg_exec_time_ns=“0s” errors=“0” working_cardinality=“0” ];
eval4 → influxdb_out5 [processed=“0”];
influxdb_out5 [avg_exec_time_ns=“0s” errors=“0” points_written=“0” working_cardinality=“0” write_errors=“0” ];
i have also checked Kapacitor stats ingress -
user@user-VivoBook-ASUSLaptop-X409JA-X409JA:~$ kapacitor stats ingress
Database Retention Policy Measurement Points Received
_kapacitor autogen edges 12461
_kapacitor autogen ingress 5125
_kapacitor autogen kafka 318
_kapacitor autogen kapacitor 688
_kapacitor autogen load 688
_kapacitor autogen nodes 11085
_kapacitor autogen runtime 688
_kapacitor autogen topics 1344
kindly help to resolve this issue to generate alerts
